Dołącz do naszej Grupy na FacebookuTempomat nie działa po wymianie skrzyni biegów
- dare50
- Auto: Insignia 4x4 COSMO
- Miasto: Wejherowo
- Postawił piwo: 30 razy
Re: Tempomat nie działa po wymianie skrzyni biegów
@wojtas69 przecież wyżej piszą ze skrzynia manual a Ty dalej piszesz nie na temat
wojtas69
- Auto: Insignia 2.8T 4x4
- Kod silnika: A28NET
Macie rację, jeśli rozchodzi się o skrzynię biegów to na schematach jest tylko czujnik pedału sprzęgła, nie ma innych. Wrzucam opis działania tempomatu i komponentów z których korzysta, miłej lektury.
Cruise Control Description and Operation
Cruise control is a speed control system that maintains a desired vehicle speed under normal driving conditions at speeds above 40 km/h (25 mph). Steep grades may cause variations in the selected vehicle speeds.
The following are the main components of the Cruise Control System:
• The accelerator pedal
• The brake pedal position (BPP) sensor
• The body control module (BCM)
• The cruise on/off switch
• The cruise control cancel switch
• The + RES switch (equivalent to resume/accel switch)
• The - SET switch (equivalent to set/coast switch)
• The engine control module (ECM)
• The throttle actuator control (TAC) motor
• The vehicle speed sensor
The body control module (BCM) monitors the signal circuit of the cruise control switches, which are located on the steering wheel. The BCM relays the cruise control switch status to the engine control module (ECM) via the serial data circuit. The ECM uses the status of the cruise control switch to determine when to capture and maintain the vehicle speed. The ECM monitors the vehicle speed signal circuit in order to determine the desired vehicle speed. The ECM uses the TAC motor in order to maintain the vehicle speed.
Voltage is supplied to the cruise control switch via the steering wheel control switch reference voltage circuit supplied by the BCM. The cruise control function switches are arranged in a resistive ladder design, with each cruise control function switch having a different resistance value. The BCM detects a specific voltage value that is associated with the cruise control function switch being activated. The BCM sends a serial data message to the ECM indicating that the on/off switch is active. Similarly, when the normally open + RES switch or the normally open - SET switch are pressed, the switch closes and the BCM detects the predetermined voltage signal on the cruise control resume/accel and set/coast switch signal circuit. The BCM sends a serial data message to the ECM indicating that the + RES switch or the - SET switch is active. The + RES switch or the - SET switch will remain inactive when the BCM has not received the predetermined voltage signal from the on/off switch.
Cruise Control Engaged
The Cruise Control System will engage and adjust vehicle speeds, based on the activation of the following cruise control switches, which are located on the steering wheel:
• On/Off
• + RES
• - SET
To engage the Cruise Control System, ensure that the vehicle speed is above 40.2 km/h (25 mph), turn the cruise On/Off switch ON and momentarily press the - SET switch. The ECM will engage the Cruise Control System and record the vehicle speed. The ECM sends a serial data message to the instrument panel cluster (IPC) in order to illuminate the Cruise Engaged indicator in the IPC.
Pressing the accelerator pedal while the Cruise Control System is engaged, allows the driver to override the Cruise Control System in order to accelerate the vehicle beyond the current set vehicle speed. When the accelerator pedal is released, the vehicle will decelerate and resume the current set vehicle speed. The driver can also override the current set vehicle speed via the - SET switch and the + RES switch. When the Cruise Control System is engaged, pressing and holding the - SET switch will allow the vehicle to decelerate from the current set vehicle speed without deactivating the Cruise Control System. When the - SET switch is released, the ECM will record the vehicle speed and maintain the vehicle speed as the new set vehicle speed. When the Cruise Control System is engaged, momentarily pressing the - SET switch will allow the vehicle to decelerate at 1.6 km/h (1 mph) increments for each time that the - SET is momentarily pressed, with a minimum vehicle speed of 37 km/h (23 mph).
Pressing and holding the + RES switch, when the Cruise Control System is engaged, will allow the vehicle to accelerate to a greater vehicle speed than the current set vehicle speed. When the + RES switch is released, the ECM will record the vehicle speed and maintain the vehicle speed as the new set vehicle speed. When the Cruise Control System is engaged, momentarily pressing the + RES switch will allow the vehicle to accelerate at 1.6 km/h (1 mph) increments for each time that the + RES switch is momentarily pressed, with the maximum acceleration total of 16 km/h (10 mph) over the current set vehicle speed. Momentarily activating the + RES switch will recall the previous vehicle speed, after the cruise control system is disengaged by pressing the brake pedal, or CANCEL switch.
Cruise Control Disengaged
The engine control module (ECM) disengages the cruise control operation based on the signals from the following switches:
• The On/Off switch
The Cruise Control System will disengage when the brake pedal is applied. The body control module (BCM) monitors the BPP sensor via the BPP sensor signal circuit as the voltage signal increases while the pedal reaches the fully applied position. The ECM monitors the BPP signal through a discrete input and a serial data message signal from the BCM indicating the brake status. When both signals indicate the brake pedal is applied, the ECM will disengage the cruise control system.
The Cruise Control System will also disengage when the cruise control on/off switch is switched OFF, or the cruise control cancel switch is activated. The body control module (BCM) determines when the cruise control cancel switch is activated. When the normally open cancel switch is closed, the BCM detects the predetermined voltage signal on the cruise control function switch circuit. The vehicle speed stored in the memory of the engine control module will be erased when the cruise control On/Off switch is turned OFF, or the ignition switch is turned OFF. The BCM sends a serial data message to the ECM in order to disengage the cruise control system. The Cruise Control System will disengage when the ECM detects that a driver override function has been active for approximately 60 seconds. When the Cruise Control System has been disengaged, the ECM sends a serial message to the instrument panel cluster (IPC) in order to turn OFF the Cruise Engaged indicator.
Every time the Cruise Control System is disengaged, the ECM will keep track of the reason for system disengagement. The last 8 disengagement reasons will be recorded within the ECM memory. The scan tool will display the last 8 Cruise Disengage History parameters, in which one out of approximately 50 possible reasons will be displayed in each of these 8 parameters. For the disengagement reason to be displayed within the scan tool parameter either the Cruise Control System is active and disengagement is requested, or engagement of the system is requested but a fault is present.
Cruise Control Inhibited
The engine control module (ECM) inhibits the cruise control operation when any of the following conditions exist:
• The ECM has not detected a brake pedal activation from the body control module (BCM).
• A Cruise Control System DTC has been set.
• The vehicle speed is less than 40.2 km/h (25 mph).
• The vehicle speed is too high.
• The vehicle is in PARK, REVERSE, NEUTRAL, or 1st gear.
• The engine RPM is low.
• The engine RPM is high.
• The system voltage is not between 9 volts and 16 volts.
• The Antilock Brake System (ABS)/Traction Control System (TCS) is active for more than 2 seconds.
• On/Off
• + RES
• - SET
• The On/Off switch
Jeśli chodzi o skrzynię manualną to jest opcja programowania (adaptacji) - dotyczy położenia neutralnego.
Drugie programowanie (adaptację), które bym rozważył, to kalibracja pedału przyspieszenia.
A trzecie co bym podejrzewał, to błędy tempomatu lub układu ABS - mogą być niedostępne z poziomu ELMa.
Nie wiem co - jest taka opcja programowania w GDS2. Do mojego AF-40 się nie nadawała (o ile pamiętam procedura nie chciała się wykonać - kończyła się błędem), więc przypuszczam, że to może do manualów jest? A po co to mnie nie pytaj
Nazywa się toto: Gear Selector -N- Position Learn (w 'Transmission Control Module' -> 'Configuration/Reset Function')
Choć z drugiej strony skoro wybrałem skrzynię AF-40 II Gen. i się to pokazało, to chyba ma zastosowanie do mojej skrzyni hmmm
EDIT: włączyłem GDS2 w trybie offline i bez interface, zmieniłem skrzynię na ręczną i jedynie co mam po wejściu w 'Transmission Control Module' to pozycja 'Global Test Menu'. Czyli chyba jednak chała z tą procedurą dla manuala...
pawelworoszylo1
Za trochę ponad 100$ masz chińskie MDI na ali. Co Ty chcesz tym robić?
- Postawił piwo: 19 razy
- Otrzymał piwo: 145 razy
Ręka długo była do góry ale z braku laku tak strzeliłem
pawelworoszylo1
pawelworoszylo1
pawelworoszylo1
Po przeskanowaniu nie ma żadnych błędów.
System widzi poprawnie położenie pedału sprzęgła hamulca i gazu. Jakieś inne pomysły? Dodam że kąt ustawienia kierownicy także jest poprawny
- Ping
- Auto: Insignia ST / MY2011
- Miasto: W-wa
- Otrzymał piwo: 146 razy
Tak jak pisze @Rooff_ zacznij od wykonania adaptacji biegu neutralnego.
Po wymianie skrzyni twój silnik "myśli" że nie ma wrzuconego biegu dlatego rozłącza tempomat.
Masz silnik 1.8? bo tam chyba nie ma czegoś takiego.
pawelworoszylo1
pawelworoszylo1
Takie coś wygrzebane. Co to może znaczyć?
- Ping
- Miasto: W-wa
Akumulator ok?
Przy rozruchu napięcie może spadać za bardzo.
pawelworoszylo1
Dziś akurat ciężko mi odpalił, jednorazowo
Dodano po 5 godzinach 2 minutach 7 sekundach:
Właśnie po przejechaniu trasy sprawdziłem i znów pokazał się ten sam błąd
