gucio
Poszperalem dziś trochę i oto co znalazłem..
DTC P2428 00: Exhaust Gas Temperature Sensor 1 - High Temperature
Diagnostic Aids
• After starting the engine, the exhaust gas temperature sensor temperature should rise steadily, then stabilize after the engine reaches operating temperature.
• If the vehicle has set overnight, the exhaust gas temperature sensor and the intake air temperature (IAT) sensor values should display within 3°C (5°F).
Reference Information
Schematic Reference
Engine Controls Schematics
Connector End View Reference
Component Connector End Views
Electrical Information Reference
• Circuit Testing
• Connector Repairs
• Testing for Intermittent Conditions and Poor Connections
• Wiring Repairs
DTC Type Reference
Powertrain Diagnostic Trouble Code (DTC) Type Definitions
Scan Tool Reference
Control Module References for scan tool information
Circuit/System Verification
1. Engine running, observe the DTC information with a scan tool. DTCs P2032, P2033 or P2428 should not set.
2. Operate the vehicle within the Conditions for Running the DTC to verify the DTC does not reset. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Circuit/System Testing
1. Ignition OFF, disconnect the harness connector at the B131 Exhaust Temperature Sensor.
2. Test for less than 5 Ω between the low reference circuit terminal 2 and ground.
⇒ If greater than the specified range, test the low reference circuit for an open/high resistance. If the circuit tests normal, replace the K20 Engine Control Module.
3. Disconnect the harness connector at the cooling fan.
4. Ignition ON, verify the scan tool Exhaust Gas Temperature Sensor 1 parameter is at 5 V.
⇒ If less than the specified range, test the signal circuit for a short to ground. If the circuit tests normal, replace the K20 Engine Control Module.
Note: If the fuse in the jumper wire opens, the signal circuit is shorted to a voltage and the sensor may be damaged.
5. Install a 1 A fused jumper wire between the signal circuit terminal 1 and ground. Verify the scan tool Exhaust Gas Temperature Sensor 1 parameter is at 0 V.
⇒ If greater than the specified range, test the signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the K20 Engine Control Module.
6. If all circuits test normal, test or replace the B131 Exhaust Temperature Sensor.
Posprawdzalem wszystkie obwody,pomierzylem rezystancje i wychodzi ze wszytko jest ok tylko że czujnik temperatury spalin nie pokazywał 3stopni a uwaga:60 przy czym silnik nawet jeszcze nie pracował...
Wysłane z HTC ONE X
Diagnostic Aids
Schematic Reference
• Circuit Testing
• Connector Repairs
• Wiring Repairs
DTC Type Reference
Scan Tool Reference
Wysłane z HTC ONE X
pawi
Jak poznajecie że zaczyna wypalać ? Wzrasta zużycie na biegu jałowym i oborty. Moje pytanie jakie powinno byc spalanie na jałowym bez wypalania i podczas wypalania oraz jakie powinyy byc przy tym odpowiednio obroty
- peja-1991
- Kod silnika: D16SHT
- Otrzymał piwo: 98 razy
Podczas wypalania poniżej tysiąca ok 800 obrotów a podczas wypalania pewnie ok 1 200- 1 500
zużycie bieg jałowy 0,7 - wypalanie 1,5
nie wiem dokładnie ale tak mi się wydaje
steq
niemieckie łby a jednak nie do końca to przemyśleli - czy nie łatwiej by było walnąć kontrolkę podczas wypalania - i sprawa rozwiązana? tak to człowiek czuje się więźniem własnego auta. Non stop przełączać na chwilowe spalanie i zerkać na obroty - masakra jakaś.
Co do spalania mam jak wyżej
picky
Tak jak mówisz, przedłużyło by się wycieczkę i filtr był by w lepszym stanie i miałby dłuższą żywotność. Ja katuje samochód na krótkich odcinkach, jak się nagrzeje to muszę go zgasić. Czuję, że zimy nie przeżyję bez awarii DPF. Może od wiosny dam jej odetchnąć świeżym powietrzem.
bolek
Taka kontrolka nigdy nie zaistnieje ,jest to maksymalnie prosta rzecz ale jest jeden problem.Zapchanie filtra to wizyta w serwisie : Podpięcie pod kompa 150zł,wypalanie wymuszone 200zł jak nie zadziała to czyszczenie mechaniczne filtra 500-600 zł,pasuje też wymienić olej po wypalaniu wymuszonym więc kolejne 300zł = 500 do 800zł. Wiecie jakie to są sumy za naprawy? Ile serwisy by straciły? Nawet nowy CLS nie ma takiej kontrolkisteq pisze:niemieckie łby a jednak nie do końca to przemyśleli - czy nie łatwiej by było walnąć kontrolkę podczas wypalania - i sprawa rozwiązana? tak to człowiek czuje się więźniem własnego auta. Non stop przełączać na chwilowe spalanie i zerkać na obroty - masakra jakaś.
tomkod
- Auto: Seat Altea
U mnie wypala sie średnio co 400-500km. Zazwyczaj zawsze to zauważam i wtedy próbuje przeganiac isie i jak naraziewszystko ok a auto tez obecnie 90% w mieście
Sent from my HTC One S using Tapatalk
- alex_k
- Auto: Opel Insignia ST
- Miasto: Bielsko-Biała
u mnie dokładnie jak u Ciebie: co 400 km, głównie miasto i tak samo staram się nie przerywać wypalaniatomkod pisze:U mnie wypala sie średnio co 400-500km. Zazwyczaj zawsze to zauważam i wtedy próbuje przeganiac isie i jak naraziewszystko ok a auto tez obecnie 90% w mieście
jak wcześniej pisałem wywalę tego pdf-a po gwarancji. to szkodliwe urządzenie i jeden z największych bubli-skandali w historii!!!
pawi
Doświadczony poprzednim francuzem konkretnie C5 proponuje montaż samemu diody informującej o wypalaniu. Opatentowano diode w lewym bocznym lusterku. Odsyłam do forum Peugeota lub Citroena tam opisano montaż. Dioda zapala się podczas wypalania, a związane jest to z cichym włączeniem grzania lusterek i tylnej szyby podczas wypalania bez sygnalizacji o tym podświetleniem przycisku.
- Cinek
U mnie rowniez co 400-500km, rowniez teraz 90% miasta, ale nie zdarzylo mi sie wypalania jeszcze przerwac, ale tak jak kolega wyzej napisal, po gwaranacji dpf out.tomkod pisze:U mnie wypala sie średnio co 400-500km. Zazwyczaj zawsze to zauważam i wtedy próbuje przeganiac isie i jak naraziewszystko ok a auto tez obecnie 90% w mieście
- Cinek
wojtassss pisze:Kolego a masz pewność, że grzeją lustra w trakcie wypalania filtra? Wepnę się chyba w lusterko z taką diodą i zobaczymyJeżeli to prawda to byłoby idealnie.
Wojtek napewno grzeja, bo silnik musi miec jak najwieksze obciazenie w trakcie wypalania
- Cinek
http://www.akuq.pl/czy_nalezy_bac_sie_dpf_lub_fapwojtassss pisze:Aaaaa tego nie wiedziałem
We wtorek jadę kupić co potrzeba
pawi
jestem pewny bo u mnie wczoraj grzalowojtassss pisze:Kolego a masz pewność, że grzeją lustra w trakcie wypalania filtra? Wepnę się chyba w lusterko z taką diodą i zobaczymyJeżeli to prawda to byłoby idealnie.
-- 11 lis 2013, o 05:43 --
zamieszczam link z forum Peugeota gdzie koledzy opatentowali diodę sygnalizująca wypalanko filtra
dioda
ery_kris
co ciekawe w instrukcji do Isi ściągniętej ze strony opla ver. 2009.pl jest informacja że podczas wypalania powinna się zapalić kontrolka - symbol świecy żarowej - i gasnąć po jego zakończeniu. Niestety nie zapala się
- peja-1991
pewnie Opel o tym zapomniał przy produkcji
szwagier
Ja miałem wczoraj wypalanie, doskonale widać po chwilowym zużyciu paliwa ale przydałaby się kontrolka... ![Zły ]:-<](./images/smilies/icon_evil.gif)
- alex_k
Jeszcze można poznać po dymieniu, przynajmniej u mnie, szczególnie np. Na światłach, kiedy auto stoi.
Wysłane z mojego LT26i przy użyciu Tapatalka
- alex_k
U mnie dymi! Ale ostatnio kazałem to w serwisie sprawdzić i powiedzieli że wszystko ok?
tomkod
- Auto: Seat Altea
U mnie to bardzo roznie, ale generalnie nie dymi. Ze dwa razy zauwazylem ze np filtr sie wypalal 5 min na drodze pozniej swiatla - ruszam i nagle za mna chmura siwego dymu
dwa razy tylko takie cos zauwazylem. Obecnie jakbym sie staral to dymu nie ma nawet na postoju sprawdzalem i nic nie leci ::)
- alex_k
Mój dpf zaczyna dawać czadu... na serio. Wg. kompa wypala się średnio co 44 km!!! W poniedziałek zdarzyło się to 2 razy w ciągu jednego dnia? Niestety oprócz stwierdzenia, że to fakt, serwis na razie nie pomógł. Nie mówię, ze nie chcą - poprosili aby podjeżdżał co 2-3 dni na podpięcie do kompa.
Czy ktoś miał już coś takiego? Zaczyna się sypać, czy to może być cos innego?
