Rozkodowanie VIN
Re: Rozkodowanie VIN
Postprzez bacapl » 13 maja 2015, o 18:02
Prosz─Ö o info
W0LGT57C991023205
Z g├│ry wielkie dzi─Öki.
bacapl
Do┼é─ůczy┼é(a): 5 mar 2015, o 07:41
Ostatnio: 23 sie 2017, o 20:43
Postprzez Putridum » 13 maja 2015, o 18:05
In english;)
Info vehicule
Model G09 INSIGNIA
Model Code 0JT69
Made 07.01.2009
Type body T5
Motor A18XER
The engine number 20MZ3206
Transmission
VIN Decoding
W0L
General Motors
G
Insignia
T5
T69 (Saloon) (Cosmo / SE/ Elite)
7
Active (manual) Belts, driver & passenger front & side & curtain air bags optional rear side & occupant sensors
C
A18XER (2H0)
9
Check Digit
9
2009
1
Russelsheim
serial
023205
Options
BLACK SEAT TRIM
TRIM COLOUR DOOR PANEL BLACK
MOULDING DOOR INTERIOR, PIANO BLACK
C18SEL[2H0],Z18XER[2H0],A18XER[2H0] PETROL ENGINE
MOULDING I/P INTERIOR PIANO BLACK
BLACK INTERIOR TRIM
WINDSCREEN,HEAT REFLECTIVE
FRONT BUCKET SEAT
RESTRAINT SEAT BELT TENSIONER, FRT
FOR SEAT WITH PARTIALLY MANUAL 6-WAY ADJUSTABLE GUIDE RAIL
LOCK, SEAT BELT WITH TENSIONER
REAR COMPARTMENT LID,REMOTE RELEASE
POWER WINDOWS, EXPRESS UP/DOWN
ELECTRICALLY OPERATED WINDOWS,REAR
4-WAY ACTIVE HEAD RESTRAINT
FOR 4 WAY POWERED LUMBAR SUPPORT
HUMIDITY SENSOR
LOCK CONTROL REMOTE ENTRY
FOR ONE TOUCH WINDOW
AIR BAG,ROOF,FRONT
HEAD RESTRAINT,REAR,VINYL,CENTER
PLATE DOOR SILL COVER
IMMOBILIZER,ELECTRIC,VARIANT 2
BREAKPOINT IDENT CONTROL
LAMP, ASSY, INTERIOR, FRONT FLOOR
NOZZLE,REAR AIR VENT
LAMP,ASSY,ROOF,WITH DUAL READING LAMP
PASSENGER AIRBAG DISABLE SWITCH
WIPER,FRONT,PULSE SYSTEM
HEADLAMP WASHER
CLIMATE CONTROL
FOR GERMANY
BOX,DEPOSIT,DRIVER SIDE
FOR EXTERIOR DOOR HANDLES WITH CHROME STRIP
SHELF,INSTRUMENT PANEL,SIDE
ARMREST REAR SEAT,STORAGE
FRONT FLOOR CONSOLE WITH SLIDING ARMREST
FOR LIGHT SENSITIVE INTERIOR MIRROR
VISOR,SUN,WITH ILLUMINATED MIRROR,RH-LH
INTERIOR ROOF CONSOLE
HOUSING
ASHTRAY AND CIGARETTE LIGHTER (SMOKERS PACK)
USED WITH MANUAL FOLDING MIRROR
POCKET,FRONT SEAT BACK,LH
POCKET,FRONT SEAT BACK,RH
TRIM SEAT CLOTH, AVENUE
POCKET, FRONT SEAT CUSHION, LH
POCKET, FRONT SEAT CUSHION, RH
SIENA LEATHER DOOR TRIM
AXLE FINAL DRIVE 4.18
ELECTRONIC STABILITY PROGRAM
EXTERIOR PAINT, SEE MODEL CATALOGUE FOREWORD PAINT CHART
CHASSIS EQUIPMENT, FRONT STRUT ASSEMBLY
CHASSIS EQUIPMENT, REAR AXLE, 4-LINK
FOR USE WITH 16" BRAKE SYSTEM
ELECTRIC PARK BRAKE
CRUISE CONTROL
BATTERY,60AH
ALTERNATOR,100AMP
HILL-START ASSISTANT
USED WITH FRONT CONSOLE ELECTRICAL RECEPTICLE
FOR AUDIO MULTIFUNCTION CONTROL
LEFT HAND DRIVE
SHIFTER INTERLOCK CLUTCH
FOR CHROME WINDOW SURROUND MOULDING
USED WITH MANUAL TRANSMISSION
MANUAL TRANSMISSION,6 SPEED (M32-6 WR)
WHEEL,ASSY.,STEERING,THREE SPOKES,LEATHER
STEERING COLUMN, ADJUSTABLE, REACH AND RAKE
POWER STEERING, NON-VARIABLE RATIO
EQUIPMENT,EUROPEAN UNION
EMISSION SYSTEM EEC 09
FOR SPACE SAVER WHEEL
WHEEL 18X8, ALUMINUM, 13 SPOKES
TYRE ALL 245/45R18-96W
FOR DAYTIME RUNNING LAMP SYSTEM
FOR REAR FOGLAMPS
FRONT FOGLAMP
FOR INTELLIGENT HIGH BEAM
LAMP INTERIOR,ROOF,REAR,COURTESY AND DUAL READING
HEADLAMP LEVELLING,AUTOMATIC
LAMP,ASSY,INTERIOR CUSTOM
LAMP INTERIOR DELUXE
HEADLAMPS DIRECTIONAL,HIGH INTENSITY DISCHARGE,LOW BEAM XENON, HIGH BEAM XENON/HALOGEN
FOR AUTOMATIC HEADLAMPS WITH TUNNEL DETECTION
SPEEDOMETER,ASSY.,K.P.H
SPEAKER,5
SENSOR,PARKING PILOT SYSTEM
FOR MONOCHROMATIC DOT MATRIX DRIVER INFORMATION CENTRE
GRAPHIC INFO - COLOUR
SEAT BELT WARNING,RH
STEERING WHEEL,CONTROL,ACCESS
LOCK CONTROL, STEERING COLUMN
WITH WIRELESS INTERFACE,SHORT RANGE,VOICE REC
ANTENNA DIVERSITY
FOR USB PORT
DVD800 NAVI
TOOL KIT
VEHICLE STATEMENT - ECE ORGANIZATION
PROTECTION WAX,DELETE
GEARSHIFT LEVER,LEATHER
FOR STEERING WHEEL RADIO OPERATION
FOR 433 MHZ FREQUENCY
Avatar u┼╝ytkownika
Putridum
Do┼é─ůczy┼é(a): 10 lut 2015, o 17:21
Ostatnio: dzisiaj, o 07:04
Pochwały: 4
Postprzez macsik » 14 maja 2015, o 06:23
bacapl napisał(a):W0LGT57C991023205
W0L:General Motors
G:Insignia
T5:T69 (Saloon) (Cosmo / SE/ Elite)
7:Active (manual) Belts, driver & passenger front & side & curtain air bags optional rear side & occupant sensors
C:A18XER (2H0)
9:Cyfra Kontrolna
9:2009
1:Russelsheim
023205:SERIAL NUMBER
01A = CZARNE WYKOŃCZENIE SIEDZENIA
1AB = KOLOR WYKOŃCZENIA PŁATU DRZWI - CZARNY
2A2 = WEWN─śTRZNA LISTWA DRZWI, CZARNY FORTEPIAN
2H0 = SILNIK BENZYNOWY C18SEL[2H0],Z18XER[2H0],A18XER[2H0]
3A5 = LISTWA WEWN. TABL. ROZDZ. - CZARNY FORTEPIAN
4AA = CZARNE WYKO┼âCZENIE WN─śTRZA
A23 = SZYBA PRZEDNIA,ODBIJAJĄCA CIEPŁO
A51 = PRZEDNIE SIEDZENIE KUBEŁKOWE
A69 = NAPINACZ PASA BEZPIECZEŃSTWA, PRZEDNI
A6B = DO SIEDZENIA Z CZ─ś┼ÜCIOWO MANUALN─ä 6-KIERUNKOW─ä PROWADNIC─ä USTAWIANIA SIEDZENIA
A6D = DO SIEDZENIA Z CZ─ś┼ÜCIOWO MANUALN─ä 6-KIERUNKOW─ä PROWADNIC─ä USTAWIANIA SIEDZENIA
A70 = BLOKADA, PAS BEZPIECZEŃSTWA Z NAPINACZEM
A90 = KLAPA PRZEDZIAŁU TYLNEGO,OTWIERANA ZDALNIE
AEF = ELEKTRYCZNE SZYBY, EKSPRESOWE OTWIERANIE/ZAMYKANIE
AER = SZYBY STEROWANE ELEKTRYCZNIE,TYŁ
AFA
AHS = ZAGŁÓWKI AKTYWNE 4-KIERUNKOWE
APG = DOTYCZY PODPARCIA L─śD┼╣WIOWEGO STEROWANEGO ELEKTRYCZNIE W 4 KIERUNKACH
APH = DOTYCZY PODPARCIA L─śD┼╣WIOWEGO STEROWANEGO ELEKTRYCZNIE W 4 KIERUNKACH
ASV = CZUJNIK WILGOTNOŚCI
ATG = STEROWANIE ZAMKIEM W SYSTEMIE ZDALNEGO OTWIERANIA/ZAMYKANIA
AXG = DOTYCZY SZYBY NA JEDNO DOTKNI─śCIE
AY0 = PODUSZKA POWIETRZNA,DACH,PRZÓD
AY9 = ZAGŁÓWEK,TYLNY,WINYLOWY,ŚRODKOWY
B9K = OSŁONA PROGU DRZWI
BAH = IMMOBILIZER,ELEKTRYCZNY,WARIANT 2
BSI = IDENT.PUNKT EFEKTYWNY CON.
C2B = O┼ÜWIETL., WN─śTRZA, ZESP., PRZEDNIA POD┼üOGA
C59 = NAWIEW,TYLNA WENTYLACJA POWIETRZNA
C95 = ŚWIATŁO,SUFITOWE,ZESP.,Z PODWÓJNĄ LAMPKĄ DO CZYTANIA
C99 = WYŁĄCZNIK PODUSZKI POWIETRZNEJ PASAŻERA
CE1 = WYCIERACZKA,PRZEDNIA,SYSTEM PRACY IMPULSOWEJ
CE4 = SPRYSKIWACZ REFLEKTORA
CJ2 = STEROWANIE KLIMATYZACJI
CT3 = DLA NIEMIEC
CT3
D61 = SCHOWEK,STRONA KIEROWCY
D7A = DOTYCZY KLAMEK ZEWN─śTRZNYCH DRZWI Z CHROMOWANYM PASKIEM
D7C = PÓŁKA,KONSOLA PRZYRZĄDÓW,BOCZNA
DA1 = PODŁOKIETNIK TYLNEGO SIEDZENIA,SCHOWEK
DBU = KONSOLA PODŁOGI PRZEDNIEJ Z PRZESUWANYM PODŁOKIETNIKIEM
DD8 = DLA LUSTERKA WEWN─śTRZNEGO CZU┼üEGO NA ┼ÜWIAT┼üO
DH6 = OSŁONA,PRZECIWSŁONECZNA,Z LUSTERKIEM OŚWIETLANYM,PRAWA-LEWA
DK6 = KONSOLA WEWN─śTRZNA SUFITOWA
DP6 = OBUDOWA
DT4 = POPIELNICZKA I ZAPALNICZKA (PAKIET DLA PAL─äCYCH)
DWE = U┼╗YWANE Z R─śCZNIE SK┼üADANYM LUSTERKIEM
EA1 = SCHOWEK,OPARCIE SIEDZENIA PRZEDNIEGO,LEWA STRONA
EA2 = SCHOWEK,OPARCIE SIEDZENIA PRZEDNIEGO,PRAWA STRONA
EAE = WYKOŃCZENIE PŁÓCIENNE SIEDZENIA, AVENUE
EPA = SCHOWEK, PODUSZKA SIEDZENIA PRZEDNIEGO, LEWA STRONA
EPB = SCHOWEK, OPARCIE SIEDZENIA PRZEDNIEGO, PRAWA STRONA
FBE = BOCZEK DRZWI SKÓRZANY SIENA
FV2 = PRZEŁOŻENIE KOŃCOWE PRZEKŁADNI GŁÓWNEJ 4.18
FX3 = PROGRAM STATECZNOŚCI ELEKTRONICZNEJ
GBI = LAKIER ZEWN─śTRZNY, PATRZ TABELA LAKIER├ôW W PRZEDMOWIE KATALOGU MODEL├ôW
GNA = WYPOSAŻENIE PODWOZIA, ZESPÓŁ PRZEDNIEGO WAHACZA
GNC = WYPOSAŻENIE PODWOZIA, TYLNA OŚ, 4-ŁĄCZNIKOWE
J60 = DO STOSOWANIA Z 16" UKŁADEM HAMULCOWYM
J71 = ELEKTRYCZNY HAMULEC POSTOJOWY
K34 = STEROWANIE TEMPOMATU
K3L = AKUMULATOR,60AH
K60 = ALTERNATOR,100A
KB5 = WSPOMAGANIE RUSZANIA NA POCHYŁOŚCI
KD4 = U┼╗YWANY Z GNIAZDEM ELEKTR. PRZEDNIEJ KONSOLI
KPA = U┼╗YWANY Z GNIAZDEM ELEKTR. PRZEDNIEJ KONSOLI
KRH
KRJ = DO WIELOFUNKCYJNEGO STEROWANIA RADIOODBIORNIKA
LHD = KIEROWNICA PO LEWEJ
M53 = SPRZ─śG┼üO BLOKADY ZMIANY BIEG├ôW
MDE = DO RAMOWEJ WYPRASKI CHROMOWEJ
MM3 = U┼╗YWANY(-A,-E) Z R─śCZN─ä SKRZYNI─ä BIEG├ôW
MZ0 = R─śCZNA SKRZYNIA BIEG├ôW,6 BIEGOWA (M32-6 WR)
N34 = KIEROWNICA,TRZY SZPRYCHY,SKÓRA,ZESP.
N37 = KOLUMNA KIEROWNICZA, REGULOWANA, WYSUWANA I POCHYLANA
N40 = WSPOMAGANIE MECHANIZMU KIEROWNICZEGO, NIEZMIENNY STOSUNEK WSPOMAGANIA
NC0 = WYPOSA┼╗ENIE,UNIA EUROPEJSKA
NE9 = SYSTEM EMISJI EEC 09
OHD
P76 = DLA SCHOWKA KOŁA ZAPASOWEGO
Q56 = KOŁO 18X8, ALUMINIUM, 13-RAMIENNE
QKD = OPONY WSZYSTKIE 245/45R18-96W
T61 = DOTYCZY UKŁADU ŚWIATEŁ DZIENNYCH (DRL)
T74
T79 = DLA TYLNYCH ŚWIATEŁ PRZECIWMGIELNYCH
T96 = PRZEDNIE ŚWIATŁO PRZECIWMGIELNE
TQ5 = DO INTELIGENTNYCH ŚWIATEŁ DROGOWYCH
TR0 = O┼ÜWIETL. WN─śTRZA,DACH,TY┼ü,OSTRZEGAWCZE I PODW├ôJNE DO CZYTANIA
TR7 = POZIOMOWANIE REFLEKTORÓW,AUTOMATYCZNE
TSP = LAMPA USTAWIANA,ZESP.,O┼ÜW. WN─śTRZA
TSQ = LAMPA WN─śTRZA DELUXE
TT2 = REFLEKTORY KIERUNKOWE,WYSOKA INTENSYWNO┼Ü─ć WY┼üADOWANIA,┼ÜWIAT┼üA KR├ôTKIE KSENONOWE, ┼ÜWIAT┼üA D┼üUGIE KSENONOWE/HALOGENOWE
TTW = DO AUTOMATYKI ŚWIATEŁ GŁÓWNYCH Z CZUJNIKIEM JAZDY W TUNELU
U18 = PR─śDKO┼ÜCIOMIERZ,ZESP.,KM/GODZ.
U65 = GŁOŚNIK,7
UD5 = CZUJNIK,SYSTEM PILOTOWY POSTOJU
UDC = DO CENTRALKI INFORMACYJNEJ KIEROWCY Z WYŚWIETLACZEM MONOCHROMATYCZNYM (MATRYCA PUNKTOWA)
UDK = INFORMACJE GRAFICZNE - WYŚWIETLACZ KOLOROWY
UH1 = OSTRZE┼╗ENIE O ZAPI─śCIU PAS├ôW BEZPIECZE┼âSTWA,PRAWA STRONA
UK3 = KO┼üO KIEROWNICY,STEROWANIE,DOST─śP
ULS = STEROWANIE BLOKAD─ä, KOLUMNA KIEROWNICZA
UPH = Z INTERFEJSEM BEZPRZEWODOWYM,KR├ôTKIM ZASI─śGIEM,ZAPISEM G┼üOSU
US3 = R├ô┼╗NORODNO┼Ü─ć ANTEN
USR = DO PORTU USB
UXX = DVD800 NAVI
V33 = ZESTAW NARZ─śDZI
V83 = DEKLARACJA POJAZDU - ORGANIZACJA ECE
VG2 = WOSK ZABEZPIECZAJ─äCY,USUN─ä─ć
VY7 = DŹWIGNIA ZMIANY BIEGÓW,SKÓRA
W1Y = DLA PRZYPADKU STEROWANIA RADIA NA KIEROWNICY
W4Y
WRA
WRB
XA3 = OPEL
XG3 = DLA NIEMIEC
XL8 = DLA CZ─śSTOTLIWO┼ÜCI 433 MHZ
Z0F = DLA NIEMIEC
Avatar u┼╝ytkownika
macsik
Do┼é─ůczy┼é(a): 4 lut 2014, o 07:52
Ostatnio: 15 lut 2016, o 21:38
Pochwały: 27
Postprzez mariuszmarysia » 14 maja 2015, o 12:04
Insignia Kombi 2.0T prosze o rozkodowanie
vin: W0LGT8GE7A1089498
Avatar u┼╝ytkownika
mariuszmarysia
Do┼é─ůczy┼é(a): 1 kwi 2015, o 15:18
Ostatnio: 23 wrz 2017, o 11:28
Auto: Insignia ST 2.0 T
Postprzez macsik » 14 maja 2015, o 12:09
mariuszmarysia napisał(a):W0LGT8GE7A1089498
W0L:General Motors
G:Insignia
T8:T35 (Estate) (Cosmo / SE / Elite)
G:Active (manual) Belts, driver & passenger front & front & rear seat side, & roof side
E:A20NHT (LDK)
7:Cyfra Kontrolna
A:2010
1:Russelsheim
089498:SERIAL NUMBER
01B = WYKOŃCZENIE SIEDZENIA JASNE NEUTRALNE
1AC = KOLOR BOCZKU DRZWI LT NEUTRALNY
2CP = WYPRASKA WEWN─śTRZNA DRZWI, DREWNO KIBO
3CG = WYPRASKA DREWNO KIBO
4AB = BR─äZOWE WYKO┼âCZENIE WN─śTRZA
6X1
7X1
8X2
9X2
A14 = SZYBA,OKNO BOCZNE,TYLNE,ZABARWIONA
AFA
AG5 = SIEDZENIE PRZEDNIE,PRAWE,REGULATOR WYSOKO┼ÜCI,R─śCZNY
AJT = DOTYCZY WARUNKÓW MONTAŻU SIATKI ZABEZPIECZAJĄCEJ
ANY = WYPOSA┼╗ENIE W SZYNY CARGO I MOCOWANIA
AQ2 = SIATKA - UDOGODNIENIE
ARH = SIATKA NA ŁADUNEK
AW7 = DO TYLNYCH BOCZNYCH PODUSZEK POWIETRZNYCH
AXJ = TYP POJAZDU, OSOBOWY
BSO = IDENT.PUNKT EFEKTYWNY CON.
CR6 = DLA POLSKI
CR6
DP6 = OBUDOWA
E94 = POKRYWA
EAF = WYKOŃCZENIE PŁÓCIENNE SIEDZENIA, SIENA
F45 = SYSTEM CI─äGLE ZMIENNEJ AMORTYZACJI ZAWIESZENIA W CZASIE RZECZYWISTYM
F46 = PODWOZIE Z NAP─śDEM NA CZTERY KO┼üA
G96 = FUNKCJA OGRANICZONEGO POŚLIZGU TRAKCYJNEGO OSI, ELEKTRONICZNA
GAL = LAKIER ZEWN─śTRZNY, PATRZ TABELA LAKIER├ôW W PRZEDMOWIE KATALOGU MODEL├ôW
GNE = WYPOSAŻENIE PODWOZIA, TYLNA OŚ, WAHACZ H
GX3
J61 = DO STOSOWANIA Z 17" UKŁADEM HAMULCOWYM
K09 = ALTERNATOR,120A
K3N = AKUMULATOR,70AH
KA1 = DLA OGRZEWANYCH SIEDZEŃ PRZEDNICH
KB7
KC8 = GNIAZDO,WYJŚCIE MOCY DODATKOWEJ
KI7 = GNIAZDO WYJ┼ÜCIOWE MOCY OSPRZ─śTU
KRH
LDK = A20NHT[LDK] SILNIK BENZYNOWY
M36 = AF40-6 PRZEKŁADNIA AUTOMATYCZNA
MM1 = UŻYWANY(-A,-E) Z AUTOMATYCZNĄ SKRZYNIĄ BIEGÓW
NV7 = WSPOMAGANIE KIEROWNICY,ZE ZMIENNĄ SIŁĄ
OAY
OHD
P77 = DLA SCHOWKA KOŁA ZAPASOWEGO
T74
TB5 = ELEKTRYCZNE OTWIERANIE DRZWI TYŁU NADWOZIA
UH5 = OSTRZE┼╗ENIE O ZAPI─śCIU PAS├ôW BEZPIECZE┼âSTWA,TY┼ü
UQA = FIRMOWY SYSTEM AUDIO Z GŁOŚNIKAMI PREMIUM I WZMACNIACZEM
URC = DLA ADAPTACYJNEGO ZAWIESZENIA FLEXRIDE
USR = DO PORTU USB
UTJ = DOTYCZY SYSTEMU AUTOALARMU
UTR = KLAKSON Z WŁASNYM ZASILANIEM,AUTOALARM
UTT = DOTYCZY SYSTEMU AUTOALARMU
UTU = CZUJNIK,WYKRYWANIE POCHYLENIA,SYSTEM AUTOALARMU
UTV = CZUJNIK,RUCH WEWN─äTRZ KABINY
UXX = DVD800 NAVI
V2T = BAGAŻNIK PRZYCZEPNY,BAGAŻNIK,DACH,POWŁOKA PROSZKOWA
V3E = BAGA┼╗NIK DACHOWY - BEZBARWNY DACH,SREBRNY
VG9 = WOSK ZABEZPIECZAJ─äCY
VGG = OCHRANIACZ TYLNEGO ZDERZAKA
VK8 = UCHWYT,OKULARY
W4Y
W9N = DLA POLSKI
WFF = 4X4
WGC = WYPOSA┼╗ENIE JEDNOSTKI ODBIORNIKA,GPS
WRA
WRB
XA3 = OPEL
XB1 = DLA POLSKI
XJ2 = OBNI┼╗ONE PODWOZIE SPORTOWE
Z0C = DLA POLSKI
Avatar u┼╝ytkownika
macsik
Pochwały: 27
Postprzez piotr200505 » 17 maja 2015, o 21:49
Cze┼Ť─ç.Prosz─Ö o rozkodowanie VINu. W0LGT8EM1B1047095. Z g├│ry dzi─Ökuje i pozdrawiam.
piotr200505
Do┼é─ůczy┼é(a): 8 maja 2015, o 22:22
Ostatnio: 23 maja 2017, o 00:06
Postprzez macsik » 18 maja 2015, o 06:17
piotr200505 napisał(a):W0LGT8EM1B1047095
W0L:General Motors
G:Insignia
E:Active (manual) Belts, driver & passenger front & front seat side, & roof side
M:A20DTH (LBS)
1:Cyfra Kontrolna
B:2011
1:Russelsheim
047095:SERIAL NUMBER
6X1
7X1
8X2
9X2
AFA
AKO = Z SZYBAMI PRZYCIEMNIANYMI
AKW = SZYBA PRZEDNIA,ZABARWIONA
CT3 = DLA NIEMIEC
CT3
DP6 = OBUDOWA
DWH = DLA LUSTERKA SKŁADANEGO ELEKTRYCZNIE
E94 = POKRYWA
EML = WYKOŃCZENIE PŁÓCIENNE SIEDZENIA, RIBBON (2)
FP9 = PRZEŁOŻENIE PRZEKŁADNI GŁÓWNEJ 3.55
GAR = LAKIER ZEWN─śTRZNY, PATRZ TABELA LAKIER├ôW W PRZEDMOWIE KATALOGU MODEL├ôW
K13 = UŻYWANY Z FILTREM CZĄSTEK STAŁYCH UKŁADU WYDECHOWEGO
K3S = AKUMULATOR,75AH
KRH
LBS = A20DTH[LBS] SILNIK WYSOKOPR─ś┼╗NY
MR6 = R─śCZNA SKRZYNIA BIEG├ôW,6 BIEGOWA,TYPU F40
OHD
Q60 = KOŁO 18X8,ALUMINIUM, 7 PODWÓJNYCH RAMION
T74
U65 = GŁOŚNIK,7
USR = DO PORTU USB
UXX = DVD800 NAVI
VRL = SPECYFIKACJA OPEL / VAUXHALL - PRZEDNIE ZAWIESZENIE POZIOME
W4Y
W7Z = WYPOSA┼╗ENIE,ZIMOWE
WRA
WRB
XA3 = OPEL
XG3 = DLA NIEMIEC
Z0F = DLA NIEMIEC
Avatar u┼╝ytkownika
macsik
Pochwały: 27
Postprzez mariuszmarysia » 21 maja 2015, o 20:08
Potrzebuje rozkodowac VIN W0LGT8EE8B1068955
Auto 4 posty wyzej okazalo sie pora┼╝ka :(
Avatar u┼╝ytkownika
mariuszmarysia
Postprzez yerry » 21 maja 2015, o 21:13
mariuszmarysia napisał(a):W0LGT8EE8B1068955
W0L:General Motors
G:Insignia
E:A20NHT (LDK)
8:Cyfra Kontrolna
B:2011
1:Russelsheim
068955:SERIAL NUMBER
6X1
7X1
8X2
9X2
AFA
CR6 = DLA POLSKI
DE8 = OSŁONA PRZECIWSŁONECZNA,SZYBA,BOCZNA TYLNA
DP6 = OBUDOWA
E94 = POKRYWA
EPY = WYKOŃCZENIE PŁÓCIENNE SIEDZENIA, RIBBON (3)
GX3
KB7
KRH
MDK = AF40-6 PRZEKŁADNIA AUTOMATYCZNA
OAY
OHD
Q00 = KOŁO 17X7, ALUMINIUM, 7-RAMIENNE
QNR = OPONY WSZYSTKIE 225/55R17-97W
QQ5 = DLA KOŁA ZAPASOWEGO O PEŁNYCH WYMIARACH
T74
USR = DO PORTU USB
UXX = DVD800 NAVI
W4Y
W9N = DLA POLSKI
WRA
WRB
XA3 = OPEL
XB1 = DLA POLSKI
Z0C = DLA POLSKI
Avatar u┼╝ytkownika
yerry
V-ce Prezes ds finansowych
Do┼é─ůczy┼é(a): 23 maja 2013, o 22:43
Ostatnio: dzisiaj, o 06:25
Pochwały: 60
Postprzez lukasz8484 » 1 cze 2015, o 15:55
witam 2.0 turbo prosze o rozkodowanie vin WOLGS87E691091760 z g├│ry dzi─Ökuj─Ö
lukasz8484
Do┼é─ůczy┼é(a): 7 mar 2015, o 20:38
Ostatnio: 22 wrz 2017, o 10:03
Postprzez yerry » 2 cze 2015, o 07:59
lukasz8484 napisał(a):W0LGS87E691091760
W0L:General Motors
G:Insignia
S8:S35 (Estate) (Sport / SRI)
E:A20NHT (LDK)
6:Cyfra Kontrolna
9:2009
1:Russelsheim
091760:SERIAL NUMBER
6Y4 = ZAPASOWE KO┼üO I OPONA,USUN─ä─ć
AE4 = DLA SIEDZEŃ SPORTOWYCH
AFA
AJH = DLA SIATKI BEZPIECZE┼âSTWA ZA PIERWSZYM RZ─śDEM
APT = SIATKA NA ŁADUNEK
CT3 = DLA NIEMIEC
DP6 = OBUDOWA
E94 = POKRYWA
EAG = WYKOŃCZENIE SKÓRZANE SIEDZENIA, SIENA
GBG = LAKIER ZEWN─śTRZNY, PATRZ TABELA LAKIER├ôW W PRZEDMOWIE KATALOGU MODEL├ôW
GY6 = PRZE┼üO┼╗ENIE PRZEK┼üADNI G┼ü├ôWNEJ MOSTU P─śDNEGO 3.76
JF5 = UŻYWANY ZE SPORTOWYM PEDAŁEM ZE STOPU
KRH
KU1 = STOSOWANY Z WENTYLATOREM SIEDZENIA KIEROWCY
MK6 = SKRZYNIA BIEGÓW MECHANICZNA 6-BIEG., OPEL, 83MM, 3.92 1ST, 0.745 6TH (F40 CR)
N35 = KOŁO KIEROWNICY,SPORT,SKÓRA
NXC = WSPOMAGANIE KIEROWNICY, ZMIENNA EFEKTYWNO┼Ü─ć WSPOMAGANIA, ZREDUKOWANY RUCH Z─śBNIKA
OER
OGA = Z POJAZDEM SPECJALNYM OPLA
OHA = LOKALNY GM W EUROPE OHA
PMA = UŻYWANE Z PRZEDŁUŻENIEM PODUSZKI SIEDZENIA
PMB = UŻYWANE Z PRZEDŁUŻENIEM PODUSZKI SIEDZENIA
Q9S = KOŁO 19X8,5, ALUMINIUM, 10-RAMIENNE
QIO = OPONY,245/40R19-98Y
T74
U65 = GŁOŚNIK,7
USR = DO PORTU USB
UWI = TELEFON KOMÓRKOWY, WIDEŁKI, ANTENA & ŁADOWANIE, KONSOLA PODŁOGOWA
UXX = DVD800 NAVI
VK0 = HAK HOLOWNICZY PRZYCZEPY,TYP OBROTOWY,MANUALNY
W4Y
WFF = 4X4
WRA
WRB
WTR = TYMCZASOWA NAPRAWA OPONY
XA3 = OPEL
XG3 = DLA NIEMIEC
Z0F = DLA NIEMIEC
Avatar u┼╝ytkownika
yerry
Pochwały: 60
Postprzez lukasz8484 » 2 cze 2015, o 08:11
dzi─Öki wielkie
lukasz8484
Postprzez asthor124 » 4 cze 2015, o 21:19
Witam, to ja te┼╝ prosz─Ö o rozkodowanie:
W0LGT8EM1D1051442
asthor124
Do┼é─ůczy┼é(a): 21 lut 2015, o 17:40
Ostatnio: 5 cze 2015, o 23:37
Auto: Skoda Octavia
Postprzez marus78 » 5 cze 2015, o 07:08
cze widz─Ö ze mamy tu profesjonalist├│w :D wi─Öc i ja poprosz─Ö o rozkodowanie
W0LGT8EM8B1087433
marus78
Do┼é─ůczy┼é(a): 23 maja 2015, o 08:10
Ostatnio: 2 wrz 2017, o 14:01
Auto: insignia 2,0 160ps
Postprzez peja-1991 » 5 cze 2015, o 10:16
W0LGT8EM8B1087433
Producent Opel
Model Insignia
Pakiet INS-ST COSMO 160CH ECOFLEX
Silnik A20DTH -17664070
Kod modelu 0JT35 Rok modelowy 2011A
Kod pakietu MDI1 Nr rejestracyjny
Kolor SZARY TECHNICAL METALIK (GAL) Data rejestracji 2011-03-03
Tapicerka Tapic.Morrocana-Ribbon czARNA (TAEJ) Kod diler FR1125
Silnik ENG-4 CYL 20L DIESEL TURBO HO (LBS) Opony 225/50 R17 98V
Skrzynia biegów TRANS-MAN 6-SP F40 FWD Koła 7Jx17
Kod Opcje Kod Opcje
TRC TRIM COLOR SEAT JET BLACK TDP TRIM COLOR DR PANEL JET BLACK
MDD MOLDING DOOR INTR PIANO BLACK2 MDI MOLDING I/P INTR PIANO BLACK
ICL INTERIOR TRIM JET BLACK FLH COMP FRT LH NON-COMP. SEL SUSP
SPW USUNIECIE KOLA ZAPASOWEGO FRH COMP FRT RH NON-COMP. SEL SUSP
RLH COMP RR LH NON-COMP. SEL SUSP RRH COMP RR RH NON-COMP. SEL SUSP
A23 przednia szyba odbijaj┬╣ca prom FST przednie siedzenia
A69 RESTRAINT SEAT BELT TENSIONER FS0 ADJ FRT ST MAN 6-WAY PWR DR
A70 napinacze pas├│w bezpiecz.prz├│d AEF POW. WINDOWS PASS EXPR UP/DOWN
A33 ELEKTRYCZNE SZYBY Z TYLU ITC INTERIOR TRIM CONFIG #1
SAR reg. wysokosci fotela pasa┬┐era AHS RESTRAINT HEAD FRT SEAT UP/D
AJT Zaczepy do moc. siatki w bagaz WNT Przyciemniane szyby tylne
WST WINDSHIELD TYPE TINTED APG CONTROL SEAT POWER LUMBAR LH
ASV EQUIPMENT SENSOR AIR MOISTURE LCE LOCK CNTRL REMOTE ENTRY STD
WOP Elektryczne szyby - impulsowe AXH VEHICLE TYPE PASSENGER CAR
AIR PODUSZKI KURTYNOWE HRC Tylny zagl├│wek szt. sk├│ra
B70 PLATE DOOR SILL COVER "OPEL" BAE immobilizer
C2B LAMP INTR FRT FLR ILLUMINATIO C59 VENT AIR CONSOLE RR
C95 lampki do czytania prz├│d AIT PASSENGER AIRBAG MANUAL CUTOFF
CE1 CZUJNIK DESZCZU (RAIN) C68 KLIMAT. AUTOM. 2STREF. (ACC)
EXP FRANCE-MANDATORY DEP TRAY DRIVER SIDE DEPOSIT
DHO HANDLE O/S DR B/C CHROMESTRIP D7C TRAY PASS SIDE DEPOSIT DIVIDER
DA5 TYLNY PODLOK Z OTW NA DL PRZED MII Lusterko wewn. -wiat┬│oczu┬│e
MRI Osl. przeciwsl. z podsw. lust COR CONSOLE ROOF INTERIOR
DP6 lusterka w kolorze nadwozia CGL Popielniczka i zapalniczka
MIR LUST PODGRZ STER I SKLAD ELEK E94 COVER RR COMPT LOADING EDGE
EA1 Kieszen tyl fotela kierowcy EA2 Kieszen tyl fotela pasazera
TLV TRIM CLOTH RIBBON (2) RAT RATIO TRANSAXLE FINAL DR.3.09
DEC TRIM DOOR PVC SIENA FX3 ESP
CCL SZARY TECHNICAL METALIK CEF CHASSIS EQUIP FRONT STRUT ASM
CEA CHASSIS EQUIP REAR AXLE 4-LINK IJL CAMPAIGN "ECOFLEX"
BRK ABS 17" FRT & RR DISC POWER J71 BRAKE PARKING POWER OPERATED
FLO filtr czastek stalych CRC tempomat (cruise control)
BAT BATTERY 12V 75AH 720 CCA GEN alternator 100AA
KB5 Wspom. ruszania pod górê KC8 gniazdo 12V w bagazniku
KD4 RECEPTACLE ELECTR FRT CONSOLE KPA POWER OUTLET REAR
K12 FILTER AIR POLLUTANT &ODOR CON POKRETLO WIELOFUNKCYJNE
ENG ENG-4 CYL 20L DIESEL TURBO HO DRV kierownica po lewej stronie
M53 SHIFTER INTERLOCK CLUTCH MLD BELT LINE MOLDING CHROME ALL
MTC TRANS-MAN MERCHANDISED EQUIP. TRN TRANS-MAN 6-SP F40 FWD
SWL Kierownica tr├│jramienna sk├│rz. SRC MAN.TILT TELESCOPING STEERING
SRS wspomaganie kierownicy NC0 WYPOSAZ UNII EUROPEJSKIEJ
EFS EMISSION-SYSTEM EEC 09 OHD MODEL UPGRADE 05
501 SUB - PACK PH3C WHL WHEEL 18x8 ALU DESIGN 5
TIR TIRES 245/45 R18-96W BW R/ST TWL SWIATLA DZIENNE
T74 swiatla asekuracyjne FLR FOGLIGHTS REAR
FLT 2 HALOG. P/MGIEL. REFLEKT.(XL) WEC ORNAM. LETTER. "ECOFLEX" RR
TRM Tapic.Morrocana-Ribbon czARNA TL2 AERODYNAMICZNE LOTKI NA SZYBIE
TR0 Lampki do czytania z ty┬│u LSL reg. ustawienia reflektor├│w pr
TSP pakiet oswietlenia/multikolor TSQ PAKIET OSWIETLENIOWY II
LGT HEADLAMPS-PENCIL HALOGEN TTW HEADL CNTRL AUTO ON-OFF TUNEL
SPD prêdko-ciomierz wyskalowany w SRE 7 GLOSNIKOW PREMIUM
UD5 pilot parkowania DIT WYSWIETLACZ GRAFICZNY M-DZY ZE
UAJ COLOR INFO DISPLAY (CID)7"QVGA UH1 INDICATOR SEAT BELT WARNING RH
ULS LOCK CONTROL STEERING COLUMN WIT PORTAL BLUETOOTH
ANT ANTENA PLETWA REKINA USR bluetooth USB - viva voice
RDO RADIO NAV DVD-ROM CAF USB RSA LUG RELINGI DACHOWE (ROOFRAIL)
LCC relingi dachowe srebrne VCS VEHICLE STATEMENT ECE ORG
WAX zabezpieczenie woskiem VGG LISTWA OCHRONNA NA BRZEG BAGAZ
VK8 etui na okulary VRL V.A. ASM FRONT HORIZONTAL SUSP
VY7 skorzana dz. zmiany biegow W1Y sterowanie radiem w kole kiero
W4Y kod pomocniczy W5T USUNIECIE OZNACZENIA SILNIKA
REC EQUIP. RECEIVING UNIT GPS WRA WIRING PROV CUSTOM WIRING BODY
WRB WIRING PROV CUSTOM WIRING (IP) WTR ZESTAW NAPRAWCZY
XJ6 CHASSIS LOWERED MODIFIED FRE kod pom. do zdalnego ster. rad
"Krytyk i eunuch z jednej s─ů parafii
obaj wiedz─ů jak, ┼╝aden nie potrafi" Tadeusz Boy-┼╗ele┼äski
Avatar u┼╝ytkownika
peja-1991
Do┼é─ůczy┼é(a): 24 kwi 2013, o 14:39
Ostatnio: dzisiaj, o 08:03
Pochwały: 34
Auto: Volvo C70
Rok produkcji: inny
Postprzez marus78 » 5 cze 2015, o 15:55
o kufa jedno nie pasi opony oryginalne i nalepki s─ů to 245/45/18 ao z reszty to nic nie wiadomo. szkoda ze nie mo┼╝na po pl. ale dzi─Öki
marus78
Postprzez bartoli777 » 9 cze 2015, o 21:21
Prosz─Ö o rozkodowanie W0LGT8EN7C1074862
Dzi─Öki
Avatar u┼╝ytkownika
bartoli777
Do┼é─ůczy┼é(a): 4 cze 2015, o 08:03
Ostatnio: 29 kwi 2017, o 05:49
Auto: Insignia ST Biturbo
Postprzez tomekw24 » 9 cze 2015, o 23:39
witam . ja rowniez poprosze o rozkodowanie VIN W0LGS8EL0C1006744. Dziekuje
tomekw24
Do┼é─ůczy┼é(a): 1 cze 2015, o 12:04
Ostatnio: 16 lut 2016, o 12:06
Postprzez yerry » 10 cze 2015, o 12:59
tomekw24 napisał(a):W0LGS8EL0C1006744
W0L:General Motors
G:Insignia
L:A20DT (LBR)
0:Check Digit
C:2012
1:Russelsheim
006744:SERIAL NUMBER
01A = BLACK SEAT TRIM
1AB = TRIM COLOUR DOOR PANEL BLACK
2A2 = MOULDING DOOR INTERIOR, PIANO BLACK
3A5 = MOULDING I/P INTERIOR PIANO BLACK
4AA = BLACK INTERIOR TRIM
5EA = CO2 REDUCTION PACKAGE
6X1
7X1
8X2
9X2
A69 = RESTRAINT SEAT BELT TENSIONER, FRT
A6B = FOR SEAT WITH PARTIALLY MANUAL 6-WAY ADJUSTABLE GUIDE RAIL
A70 = LOCK, SEAT BELT WITH TENSIONER
AE4 = FOR SPORT SEATS
AEF = POWER WINDOWS, EXPRESS UP/DOWN
AER = ELECTRICALLY OPERATED WINDOWS,REAR
AFA
AG5 = FRONT SEAT,RH,HEIGHT ADJUSTER,MANUAL
AJT = FOR SAFETY NET INSTALLATION PROVISIONS
AKL = WINDSCREEN,HEAT REFLECTIVE
AKO = WITH PRIVACY WINDOWS
APH = FOR 4 WAY POWERED LUMBAR SUPPORT
ASV = HUMIDITY SENSOR
ATG = LOCK CONTROL REMOTE ENTRY
AXG = FOR ONE TOUCH WINDOW
AXJ = VEHICLE TYPE, PASSENGER CAR
AY0 = AIR BAG,ROOF,FRONT
AY5 = HEAD RESTRAINT,REAR,CLOTH,CENTER
AYS = HEAD RESTRAINTS, DRIVER - 4 WAY, PASSENGER - 2 WAY, ACTIVE
B9L = PLATE DOOR SILL COVER
C59 = NOZZLE,REAR AIR VENT
C99 = PASSENGER AIRBAG DISABLE SWITCH
CE1 = WIPER,FRONT,PULSE SYSTEM
CJ2 = CLIMATE CONTROL
CU9 = FOR UNITED KINGDOM
CUV = EQUIPMENT ADDTIONAL UNITED KINGDOM
CV7 = ENGLAND
DA1 = ARMREST REAR SEAT,STORAGE
DD8 = MIRROR INSIDE, REAR VIEW, LIGHT SENSITIVE
DH6 = VISOR,SUN,WITH ILLUMINATED MIRROR,RH-LH
DK6 = INTERIOR ROOF CONSOLE
DP6 = HOUSING
DWH = FOR ELECTRIC FOLDING MIRROR
EA1 = POCKET,FRONT SEAT BACK,LH
EA2 = POCKET,FRONT SEAT BACK,RH
EBZ = TRIM SEAT CLOTH, RIBBON
FBD = ATLANTIS CLOTH DOOR TRIM
FHY = VEHICLE FUEL DIESEL B10
FX3 = ELECTRONIC STABILITY PROGRAM
FX4 = AXLE FINAL DRIVE 3.35
GAL = EXTERIOR PAINT, SEE MODEL CATALOGUE FOREWORD PAINT CHART
GNA = CHASSIS EQUIPMENT, FRONT STRUT ASSEMBLY
GNC = CHASSIS EQUIPMENT, REAR AXLE, 4-LINK
J60 = FOR USE WITH 16" BRAKE SYSTEM
J71 = ELECTRIC PARK BRAKE
JF5 = USED WITH SPORT ALLOY PEDAL
K13 = USED WITH EXHAUST SYSTEM PARTICLE FILTER
K34 = CRUISE CONTROL
K3W = BATTERY,12V 95AH
KB5 = HILL-START ASSISTANT
KC8 = SOCKET,ACCESSORY POWER OUTLET
KD4 = USED WITH FRONT CONSOLE ELECTRICAL RECEPTICLE
KG9 = ALTERNATOR,140AMP
KL9 = STOP/START ENGINE SYSTEM
KPA = USED WITH FRONT CONSOLE ELECTRICAL RECEPTICLE
KRJ = FOR AUDIO MULTIFUNCTION CONTROL
LBR = A20DT[LBR] DIESEL ENGINE
MCR = RECEPTACLE MEMORY CARD
MDE = FOR CHROME WINDOW SURROUND MOULDING
MF3 = MANUAL TRANSMISSION,6 SPEED (M32-6 WR)
MM3 = USED WITH MANUAL TRANSMISSION
N35 = STEERING WHEEL,SPORT,LEATHER
N37 = STEERING COLUMN, ADJUSTABLE, REACH AND RAKE
NC0 = EQUIPMENT,EUROPEAN UNION
NE9 = EMISSION SYSTEM EEC 09
NJ1 = POWER STEERING, NON-VARIABLE RATIO, ELECTRIC STANDARD RACK TRAVEL
OHA = LOCAL GM OF EUROPE OHA
PMB = USED WITH SEAT CUSHION EXTENSION
Q02 = WHEEL 18X8,ALUMINUM, 5 TWIN SPOKES
QKD = TYRE ALL 245/45R18-96W
QQ5 = FOR FULL SIZE SPARE WHEEL
RHD = RIGHT HAND DRIVE
T3U = FRONT FOGLAMP
T4A = HEADLAMPS,HALOGEN
T61 = FOR DAYTIME RUNNING LAMP SYSTEM
T79 = FOR REAR FOGLAMPS
T94 = HEADLAMPS,LH TRAFFIC
T9T = 'ECOFLEX'
TB5 = TAILGATE POWER OPENING
TR6 = HEADLAMP LEVELLING,MANUAL
TSP = LAMP,ASSY,INTERIOR CUSTOM
TSQ = LAMP INTERIOR DELUXE
TTV = SPOILER,REAR,TAIL GATE
TTW = FOR AUTOMATIC HEADLAMPS WITH TUNNEL DETECTION
U65 = SPEAKER,7
UCU = RADIO NAVI 600
UD5 = SENSOR,PARKING PILOT SYSTEM
UDC = FOR MONOCHROMATIC DOT MATRIX DRIVER INFORMATION CENTRE
UDK = GRAPHIC INFO - COLOUR
UH0 = SEAT BELT WARNING,LH
UJN = TYRE PRESSURE MONITORING SYSTEM
ULS = LOCK CONTROL, STEERING COLUMN
UMN = SPEEDOMETER INST,KILO & MILES,MILES ODOMETER,POSITIVE BIAS
UPH = WITH WIRELESS INTERFACE,SHORT RANGE,VOICE REC
US3 = ANTENNA DIVERSITY
USR = FOR USB PORT
UTJ = FOR THEFT DETERRENT SYSTEM
UTR = SELF POWERED HORN,ANTI-THEFT SYSTEM
UTT = FOR THEFT DETERRENT SYSTEM
UTU = SENSOR,INCLINE DETECTION,ANTI-THEFT WARNING SYSTEM
UTV = SENSOR,INTERIOR MOVEMENT
V2T = CARRIER,LUGGAGE,ROOF,POWDER COATED
V33 = TOOL KIT
V3E = LUGGAGE CARRIER CLEAR ROOF,SILVER
V83 = VEHICLE STATEMENT - ECE ORGANIZATION
VG2 = PROTECTION WAX,DELETE
VGG = REAR BUMPER PROTECTOR
VK0 = TRAILER HITCH HOOK,SWIVEL TYPE,MANUAL
VK8 = HOLDER,EYE GLASSES
VRL = OPEL / VAUXHALL SPECIFICATION - FRONT HORIZONTIAL SUSPENSION
VY7 = GEARSHIFT LEVER,LEATHER
W1Y = FOR STEERING WHEEL RADIO OPERATION
W4Y
W5T = ENGINE BADGE,DELETED
W9X = LETTERING,SRI
WGC = EQUIPMENT RECEIVING UNIT,GPS
WRA
WRB
WRC
XFE = FOR FUEL ECONOMY PACKAGE
XJ2 = LOWERED SPORTS CHASSIS
XL8 = FOR 433 MHZ FREQUENCY
XN8 = FOR GREAT BRITAIN
XQ2 = FOR VAUXHALL
Y95 = NAMEPLATE,VAUXHALL
Avatar u┼╝ytkownika
yerry
Pochwały: 60
Postprzez melon31 » 11 cze 2015, o 17:28
Witam prosz─Ö o rozkodowanie dw├│ch nr Vin
W0lGT8EM4B1030095
W0LGT8EM1B1110518
melon31
Do┼é─ůczy┼é(a): 9 cze 2015, o 21:36
Ostatnio: 30 cze 2015, o 22:33
Auto: Audi
Poprzednia stronaNast─Öpna strona
Powr├│t do Dyskusje og├│lne
Kto przegl─ůda forum
U┼╝ytkownicy przegl─ůdaj─ůcy ten dzia┼é: Brak zidentyfikowanych u┼╝ytkownik├│w i 1 go┼Ť─ç
